The most likely cause of this is either we have a leak, or they did not fill the unit enough when the topped it off.
Either way we need to start with checking the level of the fluid.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Next, we need to inspect for a leak if it is low.
Here is a guide that will help with this as I assume the leak will be with the pan gasket that was just changed:
I highly doubt that this would have anything to do with changing the fluid as the mileage was not that high so I suspect we will find something with the above info.
Please run through this info and let us know what you find with this. Thanks
Oct 21, 2021 at 7:49 PM
