I change the regular engine oil and filter on the Ford Taurus. I started the car checked for leaks and then backed the car off of the car ramps. I then cut the car off, let it set for a while, rechecked the oil to make sure if was at the proper level. I then restarted the car and attempted to back the car. The car will not go forward or backward or even attempt to. It is almost like the linkage is disconnected but upon checking everything seems fine. I have replaced one sensor that is connected to the linkage and is mounted on the transmission, but did not help. Do you have any suggestions?
Jul 10, 2008 at 5:44 PM
