The front rotors have been a problem from the beginning,I've owned the since new,the dealer has replaced the rotors and pads three times with the rotors being turned numerous times in between,I have had this done a fourth time at an independent shop because it didn't cost me nearly as much and I figured that if they warp again at least I didn't spend as much as I did at the dealer.They all seem indifferent to this problem and in researching this problem on the internet I see I'm not alone,by the way I owned a 1993 aerostar with similar brake problems,seems to be a pattern.I hope you can help.
Apr 12, 2008 at 12:13 PM
