2003 Ford Taurus problem unknown
2003 FORD TAURUS
113,000 MILES • 6 CYL • FWD • AUTOMATIC
HEATHERHANSON
I have a 2003 taurus that is jerking with high rpm's. It doesn't matter if the car is in drive or if it is parked. I have spoken to several people and get different answers. I THINK I have it narrowed down to the IAC or the MAP sensor. Am i on the right track?
Jan 11, 2008 at 4:04 PM
BLACKOP555
  • 10,386 POSTS
IAC wouldnt affect the vehicle on high speeds. but the MAP, EGR, MAF sensor all will. clean them all, also check for vaccum leaks by using carb cleaner sprayed on all hoses and aroudn intake manifold when vehicle is running. if idle is changed you have found a leak.
Jan 11, 2008 at 7:07 PM
