2003 Ford Taurus---possible heating coil issue
2003 FORD TAURUS
ERYN6683
I noticed this morning that there was a good size puddle on the floor in the front on the passenger side. Is this from a busted heating coil?? If so, what is a rough estimate of getting this fixed? I just need some sort of idea here.
Thanks.
Nov 17, 2006 at 9:54 AM
BRUCE HUNT
  • 3,754 POSTS
Did you check the fluid to determine if it was antifreeze or water? If it is antifreeze then you do have a heater core problem, if not and it is water then two issues are possible. One rain and a plugged drain. Two A/C condensation moisture and a plugged drain.
Nov 17, 2006 at 11:06 AM
