2002 Ford Taurus Upper upper radiator hose
2002 FORD TAURUS
110,000 MILES • 6 CYL • FWD • AUTOMATIC
TAURUS0513
My upper upper radiator hose began to leak from the connection point coming from the reserve into the upper radiator hose assembly. Can i just replace the smaller part or do i have to buy the whole assembly? When i called the delearship they said the assembly is around $150 but i checked online and the part# Km-3026 is available for around $40
Jan 14, 2010 at 10:50 AM
BMRFIXIT
  • 19,053 POSTS
The hose is available for a lot less through the after market
and the # you supplied I think its for the hose assembly and should do just fine
good luck
Jan 14, 2010 at 5:37 PM
CHAD
Taurus0513,
My 2002 taurus is leaking from the same spot. I ordered the part from Napa for around $40. Did you have any luck replacing it? I can't figure out some of the hose connectors.
Jan 19, 2011 at 1:57 PM
BINSAMP
This hose is designed to fail and damage your engine. It is very expensive here in Canada and difficult to replace.
May 19, 2011 at 2:54 AM
