2002 Ford Taurus heads
2002 FORD TAURUS
JAHLELLE1423
Engine Performance problem
2002 Ford Taurus 6 cyl Automatic 149000 miles
ok lets start from the beginning, my car began to overheat due to a crack in the water container. thus leading to no water circulating the engine. I kind of just blew off the problem and it got worse. My car was having a hard time accelerating and was making a ous clacking noise. I change the water container and the roblem went away.
After a while the car wouldn't overheat, but all of the water from the container would steam out.. I thought it was the container cap, so i bought a new cap and the problem was still the same. I was driving on the freeway and i was going about 80 miles an hour and the car was beginning to shut off. The loud clacking sound came back, but the water temperature was not very high. I pulled into a gas station and took off the cap to the water container and all the water rushed out at a high temperature.
I replaced the water and at first when i started the car it had a really rough shaking and then it was smooth. Then i shut car off and it began to steam out again.
I thought it was the thermostat so i changed ot. and the problem persist.I then started it up and rev the engine and the engine power was very weak. I checked the spark plugs and the gap was at like one thousandths. While replacing the spark plugs 4 and 6 were wet.
now my question is.. are my heads cracked. or do i just need to change some gaskets. what do i need to do. any help will be great.
p.s sorry for the length
Aug 25, 2008 at 1:44 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
you will have to have a head check done, this will show any exhaust gasses in the cooling system, if so and i feel that you will, you should have the heads crack tested & pressure tested just in case, you don't want to do all that work only to find that there is a hair line crack in a head. Also have the radiator cleaned & flow tested as well.
Mark (mhpautos)
Aug 25, 2008 at 1:50 AM
JAHLELLE1423
where could i go to get this done, what exactly do i ask them to check, also if it is just a hair line fracture, what do i need to do to fix it
Aug 25, 2008 at 2:28 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
your local mechanic can take care of this for you, you will need to ask for a head check and report, explain what you have experienced with the car. If the test shows positive the heads will be removed & an automotive machinist will do the repair, the head will be crack tested and any faults will be welded and tested, this is all quite normal procedure.
Mark (mhpautos)
Aug 25, 2008 at 3:44 AM
