2002 Ford Taurus Brake fluid leaking
2002 FORD TAURUS
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
SQUID1986
I was driving my daughters car and noticed the brake light was on. I checked the emergancy brake and that was not it. When I got home I checked the brake fluid and saw it was low, so I added more as I did so I pumped the brakes and saw that it was all leaking out at the rear driver side tire. I twas not coming from the brake lines running under the car but from the rotor itself. What do I need to do and how much will this cost.
Jan 5, 2010 at 12:34 PM
BMRFIXIT
  • 19,053 POSTS
If have shoes and drums in the rear suspect and replace wheel cylinder
if have calipers and rotor
check caliper and pads
Jan 5, 2010 at 8:21 PM
