2002 Ford Taurus Blower Fan Resistor
2002 FORD TAURUS
73,000 MILES • 6 CYL • FWD • AUTOMATIC
HANDBALL21
  • 6 POSTS
Can you provide me detailed "how to" instructions on replacing the blower fan resistor on my Ford Taurus. My mechanic wants to charge me $125 and the part is only $20 so I'd like to see if its something I can do myself. Thanks!
Oct 22, 2010 at 11:08 AM
WRENCHTECH
  • 20,761 POSTS
Do you have an auto temp control system?
Oct 22, 2010 at 11:22 AM
HANDBALL21
  • 6 POSTS
No
Oct 22, 2010 at 11:46 AM
WRENCHTECH
  • 20,761 POSTS
Then I don't know why the price is so high. It's a 1/2 hour job tops. Two screws and unplug the wire. The labor should be around $40. Your part is a little low though. Your probably getting some Chinese junk for that price.
REMOVAL
1. Remove the right-side instrument panel insulator.
2. Remove the blower motor resistor.
1 Disconnect the electrical connector.
2 Remove the screws.
3 Remove the blower motor resistor.
INSTALLATION
1. To install, reverse the removal procedure.
Oct 22, 2010 at 12:18 PM
HANDBALL21
  • 6 POSTS
That does sound easy which is great! I don't have an extra $100 to spend.
I'll show my ignorance...where is this instrument "insulator"..under the hood (if so, where should I look there) or inside the cabin (same question).
The part is coming from O'Rielly Auto Parts. I'll see if that have an OEM version.
Thanks for the help!
Oct 22, 2010 at 2:23 PM
WRENCHTECH
  • 20,761 POSTS
Under the dash, passenger side
Oct 22, 2010 at 2:25 PM
HANDBALL21
  • 6 POSTS
thanks!!
Oct 22, 2010 at 2:39 PM
