power windows not working
2002 FORD TAURUS
MCMURRAYSC
I just purchased a 2002 Ford Taurus SES at an auto auction. After purchase I realized that I could not get the drivers window to go up. None of the windows seem able to go up or down. There seems to be no other electrical problems. Radio, interior lights, rear defrost, etc. all seem to work fine. I have a manual and checked it for location of a fuse for the windows but it does not provide a location. Searching the web has turned up nothing except similar results where others have not been able to locate a fuse for the windows. I can hear a relay engage if I press the auto down on the drivers window switch but that is all. I already tried the master switch and checked fuses but nothing seems to work.
Did you ever find a solution for your problem?Any help appreciated.
Mar 15, 2008 at 11:19 PM
There is a one touch window relay and an accessory relay that needs to be checked and the fuses as well (10, 11 and 26). I would start by checking the fuse and if its okay try the relay. Here are a couple of guides and window wiring diagrams (below) to help you see how the system works.
and
Please let us know what happens so it will help others.
Sep 7, 2017 at 12:01 PM
TAZ82277
Hey, I got a 2003 Ford Taurus myself and O2 in the 03 Ford Taurus have the same a fuse box and GEM which is the controls are anything that has a switch on it as well as your keyless entry and all. I had a problem where my windows wouldn't go up and down, my internal lights wouldn't work properly and I was having problems to radio. my problem was I had a bad fuse box just wanted to wiring harness plugs ripped out and I also had a problem with the the gem on the back of the fuse box. It started to go bad you might want to check them first if you have any problems with your windows in your interior lights because that's where it is. one of the problems with these cars I swapped out my fuse box in my GEM had no problem only thing do you need to remember is when you swap out the jam on the back of the fuse box you need to make sure you get the key fob for that module. You are going to need to go to somebody and get key fob program to it and I will apologize to you now for any problems with a my text because I used talk to text.
Jan 25, 2021 at 10:03 AM
I'm sorry did you fix the problem or are you still having issues?
Jan 25, 2021 at 11:33 AM
TAZ82277
Yeah, I did check the switches and everything and when it got down to it because of where the fuse boxes located you do have a tendency of kicking it with your foot. One of my problems was is the fact that the capture nut in the plastic where the plug goes actually came loose so the plug wouldn't stay connected to the fuse box and that was one of the issues. the other issue was the fact that some of the circuitry in the gym was shorted out and which was causing me issues with a lot of different things, actually caused my PCM relay to stay open which shorted it out. that's why I said check the fuse box quiz that is actually one of the big problems with the Ford Taurus that those shoes boxes to go bed and the gym goes bad and you can't put. I did find out you can't put a 04 or 01 Torresdale gym behind the fuse box of a 02 or 03 you can only use an O2 or O3 in an o-3 or number 2 . I was literally going nuts ripping my hair out until I figured out exactly what the problem was. I wish I would have known because I could have just replace the relay instead of spending all the money on getting another fuse box and other things and it just wound up costing me money. that's why I said check the fuse box and the gym is gym does that it stops window from working at times and sometimes it lets it work the other thing is is the gym. also if that goes bad can cause your dome lights to stay on. we're not work at all is well as other things use the gym actually controls anything that has a switch from what my research had told me person actually told me to look at the gym and the fuse box was a mechanic for Ford he's a friend of mine and we work together in a couple shops and I trusted what he said and it led me on the right path. I'm so thankful that somebody actually gave me a 2003 Ford Taurus deluxe model did I've been stripping Parts off of for my 2003 Ford Taurus. I hope this helps and good luck.
Jan 25, 2021 at 10:15 PM
TAZ82277
Oh, I just figured I'd let you know also one of the things didn't also led me to the fact there was a fuse box was when I put my foot on the fuse box or kicked it my windows would start working and so would my lights my dome lights and all it's just a stupid dumb little test that you can do today if it works then you know you have a problem with the fuse box if it don't work then your problem somewhere else is just one of the things that I was told to do and I did it and it work like a charm.
Jan 25, 2021 at 10:22 PM
Please feel free to use 2CarPros anytime!
Jan 26, 2021 at 11:35 AM
SB1TWO
My drivers window occasionally stops working and will not move up or down when the button is pressed then all of a sudden it starts working again somewhere between a few hours to a few days later
Jan 26, 2021 at 11:41 AM (Merged)
chances are the switch is going bad. WHen it stops working, you need to remove the door panel and see if there is power getting to the motor. If there is , the motor may be the problem. If there is no power, go to the switch to make sure it is getting power in and out.
FFISHBALL55
The switch of the driver's power window is not working. The 3 others switches and windows are working. I'd like to open the window panel to check what is defective. I took off the 4 screws off the panel, but I'm afraid to pry it that I might break something. I need your advise, please.
Jan 26, 2021 at 11:42 AM (Merged)
MERLIN2021
  • 17,250 POSTS
It could be the main window switch that is bad or the GEM module here is a guide to show you how to check for power so you can follow when the system losing power so you can tell what the problem is.
https://www.2carpros.com/articles/electric-window-repair
and
Here are the wiring diagrams to help you with the test and to see how the system works.
Check out the diagrams (Below). Please let us know what you find.
Cheers
STEVEMCBRIDE
Thanks for the information it was the switch that was bad I got a new one for $56.00 all set thanks for your help i love this site.
KOOLAUTOS
I had the same problem all fixed thanks!
FFISHBALL55
I want to take a look inside the panel of the driver's side window. The driver's power window is not working. I already got the srews out, and I might break something if I pry it off. any suggestion on the power window? All the other three windows are working.
Chances are the motor has gone bad. If you have all of the screws out, there are clips between the panel and the door. They will need pried apart. If you are concerned, stop at a body shop and they will show you how to remove it.
CEOSCAR
I do not turn on the car for two days and work the windows well, but if I turn off the car and turn it on again at that same moment and the windows do not work.
In these hot days do not work, but notice that in the morning when it is cold, the windows work, but the car warms up and the windows do not work.
What can be?
Jan 26, 2021 at 11:43 AM (Merged)
It sounds like a relay is having a problem and the switch is not getting power. Here are some guides to help you do some simple testing to see what the problem is:
There is an accessory relay that powers the system.
and
ADEN
having a problem when i try too open or close drivers side window it making a clicking sound between the dash or below the dash
MHPAUTOS
  • 31,937 POSTS
Hi there,
It sounds as if you may have a faulty relay, i would get this checked out first. I have lost access to our data base, but if i get back in with in the next few days i will see if i can post a pic of its location.
Mark (mhp autos)
SNOOGENS
i have the same problem. would be thankful for some advice, like repair cost or is this something i can fix my self (not knowing much at all about cars)
CPS6568
Electrical problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
I just bought this car at auction so I do not know all the history, nor can I ask the seller.
The front power windows work fine, but the back do not at all. I know it could be possible that BOTH motors are out, but could it be something simpler (and cheaper) I can test. I think I see that 1 fuse covers all power windows, so it wouln't be that. Any suggestions?
Jan 26, 2021 at 11:44 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Do not eliminate the possibility of two motors out
1st step should be , to remove the door trim and check for power and ground at window motor
This guide will help us fix it
if you have both tap on the motor or the area around it while holding the switch
KEVINLOKEN
  • 74 POSTS
i have a problem but just with driver window it went down but now doesnt work at all .all other windows work fine ,when i press driver window button i hear a clicking noise coming from under dash i thought it would be power window relay and no it wasnt problem PLZ HELP its weird when i turn off car when i press the lock button twice and key is out of ignition i can still put any other window down until interior light clicks off
Could be the battery saver or the accessory delay relay and the generic control module under left side of I/P and also the master switch itself
KEVINLOKEN
  • 74 POSTS
thanks for the quick reply just curious what the generic control module looks like ? or the master switch itself ? or battery saver
The master control switch is the one you control the rest of the window from the driver side-open the driver's window and investigate closely why it won't go back up
KEVINLOKEN
  • 74 POSTS
so i took door panel off and i was looking around and nothing looks wrong i seen motor for window i touched it and it was pretty hot could i be the darn motor is shot ? sorry i can fix most things on a car but when it comes to electrical im screwed lol
Disconnect the motor pigtail and apply power to it and then reverse the power lead did it turn either way?-nothing happens -consider replacing it-
TJCANGEMI
My driver side window will not go up! I pulled some things apart and have come to the conclusion that it is the relay for the window. My problem is that I just want to get the window up one last time. I took the door panel off and tried to push it up by hand, but it seems as if it is locked in place. Can you tell me if there is something locking it down there? And if so any suggestions on how I can unlock it to manually put it up? Please HELP!
BFM357
I had the same problem a couple of weeks ago and the first thing I did was check all the fuses which of course were all good. What I did that fixed my problem was to switch the window lock switch back and forth several times and then it worked and have had no problem since.
I don't know if it fixed the problem maybe because of dirt or dust that had fallen into the switch or maybe I was just lucky. Anyway you might try it to see if something that simple can fix your problem also.
Brent
Jan 26, 2021 at 11:45 AM (Merged)
MY02TAURUS
  • 4 POSTS
This might help someone out there,seems a issue with all 02 fords I have,when the windows,door locks or interior lights started acting up,I found the wiring tubes from the fender to the doors was getting water in them and the wires were wearing,for a quick fix I cut the bottom of the tubes they were half full of water,,once I got them dried out I fixed the wires that we rubbed thru..you can either cut the boots off,as I did,or just put cuts so any water getting in can drain out the bottom,I had lights coming on it the middle of the night draining my battery,as well as when I was driving in the rain..this fixed the issues..hope it helps..
Jun 22, 2023 at 2:07 PM
MY02TAURUS
  • 4 POSTS
02 f150 supercrew ,window stuck in down position I sprayed the buttons and was able to get it up by shaking the wireing tube from fender to door..sure enough..frayed wireing was shorted in water in the tube..got window up..will repair in dry weather
Jun 22, 2023 at 2:13 PM
Thanks for letting us know, we are here to help if you need us.
Jun 23, 2023 at 10:22 AM
