2001 Ford Taurus vaccume leak? and tune up
2001 FORD TAURUS
TXTURTLELYTIGER
  • 23 POSTS
Engine Performance problem
2001 Ford Taurus Automatic
im due for a tune up next week and i already had all the oil stuff done and the fuel filter replaced. I was wondering if anybody can give me a list of all of the 2001 ford taurus sensors..... and i think my car has a vaccume leak? it acts like it age or older , rough idleling, doesnt like going up hill , sputters, has a problem with accelerating like it is working harder to get up-speed and i have to sometimes press down on the acceleration a bunch of times to get it to speed, and it sometimes messes up on the throttle with unexpected burts of speed sometimes when or after starting/moving the taurus . im not sure if its the throttle or engine knock? thx
Jul 10, 2010 at 10:49 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Jul 11, 2010 at 2:12 AM
