2001 ford taurus v6 auto transmission service questions
2001 FORD TAURUS
MARINM1
1. can you drain the torque converter, on a service and does it have a metal or fiber filter?
2. if you have the transmission machine flushed, is there a chance of dislodging foreign material and that material causing problems in the valve body etc.
Feb 25, 2007 at 5:13 PM
CHEVY22
  • 1,375 POSTS
using a flush machine will pull most of the fluid out of the converter , the filter is metal with a fiber inner core , and yes there is may be a problem with cleaning material from the v/b , the flush machine i used we fill with 16 quarts and start the flush using more flluid enabled us to overflush the system and try to get rid of anything
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 25, 2007 at 6:30 PM
MARINM1
I do not think i stated the first question correctly.
If I was too service this transmission the manual way
IE. Drop the pan and relplace the filter. Is there an access panel and a pipe plug fitting on the torque converter to open and drain the converter like the old
c-4 and c-6 transmissions used to have. If not, is machine flushing the only method of effectivley changing out the fluid?
thanks
Feb 26, 2007 at 6:18 PM
CHEVY22
  • 1,375 POSTS
no plug , if you want to get it all out go for the flush , the only thing i dont like about the flush is your old filter is still there , but they work pretty good and they ony cost about 120.00
hope i helped
thanks, jim
Feb 26, 2007 at 6:24 PM
MARINM1
thanks jim, I figured they eliminated the plug by now.
ps: in the old days we used to drill and tap the converter and install an 1/8 pipe plug (very carefully).
thanks again....
Feb 26, 2007 at 9:34 PM
CHEVY22
  • 1,375 POSTS
im 37 and i remember doing it too , remember when the converters used to bolt together ?? about 5 years ago they started making them for racecars funny
thanks take care and good luck
jim
Feb 26, 2007 at 9:44 PM
