2001 Ford Taurus Transmission Fluid
2001 FORD TAURUS
BARB101356
Transmission problem
2001 Ford Taurus 6 cyl Front Wheel Drive Automatic
Ijust has the transmission filter changed and all the vents blown out by my favorite mechanic. Well, the transmission fluid is leaking, but I dont know where it is going. There is no puddle on the ground or anything like that. I did notice however, that the car was also low on coolant. It happened again today, but, the coolant level was good. Where can the transmission fluid be going?
May 20, 2010 at 8:08 PM
SERVICE WRITER
  • 9,123 POSTS
The transmission cooler in the radiator, ( leaking into the coolant), or leaking external. These are the only two possibilities.
May 20, 2010 at 8:18 PM
