2001 Ford Taurus Ignition Switch
2001 FORD TAURUS
RLADAMSJR
Electrical problem
2001 Ford Taurus 6 cyl Two Wheel Drive Automatic
Where do you find the ignition switch? I have already taken out the ignition cylinder but still don't see where the switch is? Thanks!!
Jul 1, 2010 at 9:53 AM
RICHZOMBIE
  • 173 POSTS
The ignition (electrical) switch is located on the steering column and most times on the bottom. Remove the panel from the drivers side to expose the steering column. There should be two torx screws holding it in place. Remove the screws and pull down.
Jul 1, 2010 at 10:05 AM
