2001 Ford Taurus Harsh Neutral to Drive
2001 FORD TAURUS
55,000 MILES • 6 CYL • FWD • AUTOMATIC
RALONZO
2001 Ford Taurus automatic with 55kmiles. When shifting to drive transmission jerks, it gets worse as car warms up. But once in drive transmission shifts in all speed smoothly also neutral to reverse with no problem. On a hill the car can coast on neutral about 15' then shift to drive and no jerking motion. Is the valve body serviceable without dropping the tranny? Tech Manual talk about engagement control valve,neutral-drive accumulator and oil pressure could be the problem. Transmission shop said it will cost between $1300- 2000 to repair.Any ideas
Thank you for your help.
May 21, 2010 at 3:37 AM
BMRFIXIT
  • 19,053 POSTS
Unfortunately need codes or have to take the tranny apart, for check up
and with out code what you have for price is about far and within reason
May 21, 2010 at 5:56 AM
