2001 Ford Taurus Fuel pump not coming on at startup
2001 FORD TAURUS
49,500 MILES • 6 CYL • 2WD • AUTOMATIC
TOOLMANFOB
i have an issue with my car that i need some ideas. car runs great when started. no issues!. when i stop the car and restart within about an hour the fuel pump does not come on. the engine tries to start spitting and sputtering then dies. i then wait about an hour, engine is cooled down, try to start no luck turn the key off then try again and fuel pump comes on and all is well until i stop it again. any ideas!
Feb 15, 2010 at 3:46 PM
BMRFIXIT
  • 19,053 POSTS
When it fails start with key on engine off do you have check engine light
Also check relay
Feb 15, 2010 at 5:43 PM
TOOLMANFOB
Thanks for getting back to me. No check engine light. Although when starting all the engine lights are going through the light bulb check so i can not tell if the check engine light is on all the time. also i replaced the fuel relay and this did not have any effect.
Feb 15, 2010 at 5:47 PM
MUND
  • 6 POSTS
[quote:a8968d33f1="BMRFIXIT"]When it fails start with key on engine off do you have check engine light
Also check relay[/quote:a8968d33f1]
when it wont start check to see if it is getting power to the pig tail connector
Feb 15, 2010 at 6:10 PM
