In cold weather: fob does not always unlock doors. Driver side door, when unlocked and opened will not close - mechanism does not work right when door is pushed against frame to close. This is 3rd winter for problem. Last December (08) after some problems and spraying in the lock mechanism, which fixed only briefly, dealer replaced driver door lock mechanism - it was fine the rest of the winter, but is now having problems again (and I have moved to another state). To this point, hitting the door's lock/unlock button several times (the one that unlocks all doors at once) will loosen the thing up so I can close the door. What might be wrong? What can I do?
Dec 30, 2009 at 7:41 AM
