First sorry it took so long to get back had my Wifes B-day this weekend my son's is next weekend. Anyway I would like to check the incar temperature sensor first. Unplug the three pin harnes to the incar temp sensor then measure the resistance of the terminals on the sensor itself. If the car is cold then just use air temp for reference here (once you check it start the car and do what it takes to make the clutch no kick in then shut the car off and do the test again just note the temp inside so you can use the reference included ok) is what you should find. 50-68 deg. 37,000 to 58,000 - 68-86 deg should read 24,000 to 37,000 ohms and 86 - 104 should read 16,000 to 24,000 ohms. Let me know what you find. I have included a pic of the connector and the sensor is located in the vent tube near the climate controls. Let me know what you find here. If the readings are not correct then that sensor needs to be replaced.
May 5, 2009 at 10:02 AM
