2001 Ford Taurus coil pack
2001 FORD TAURUS
FALCON0012000
The mechanics around my town suck. They cant figure out why the car is misfiring on cylinder #1. The car has the 24 valve dohc engine. I have had people say that it is the drivetrain, the fuel system, the plugs or wires, the timing and a bunch of other bogus diagnostics. :? Is it possible that the coil on the #1 cylinder is going bad? (like i keep telling them)if so where is the coil pack and how do I swap the bad coil. I have replaced virtually all fuel system componets, had the drivetrain thoroughly inspected at a transmission shop, would love to know how to check the timing on a car that doesn't have a distributor in the first place, :?: and whose timing is computer controlled. HELP!!!
Dec 23, 2006 at 6:15 PM
MATHIASO
  • 1,209 POSTS
Engine misfiring can be caused by burned valves or by some internal engine problem.Intermittent misfiring is usually caused by an ignition problem.Check for the following:
fouled or worn spark plugs
improperly gapped spark plugs
Damaged insulation on secondary wires,or disconnected wires
Cracked distributor cap
Carbon tracks in rotor
worn didtributor shaft
Dec 23, 2006 at 8:17 PM
