2000 Ford Taurus shaking tire on passinger side
2000 FORD TAURUS
14,000 MILES • 4 CYL • 4WD • AUTOMATIC
DOVES81
when on fwy the front tire on passinger side is shaking and steering wheel too. we just put a new axle on it. and the brakes are new. what could be the problem.
Feb 26, 2009 at 5:31 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:fe10c8b8ef="doves81"]2000 Ford Taurus 4 cyl Four Wheel Drive Automatic 14000 miles
when on fwy the front tire on passinger side is shaking and steering wheel too. we just put a new axle on it. and the brakes are new. what could be the problem.[/quote:fe10c8b8ef]
It could be the wheel bearing or the tire tread has seperated.
Jack up the vehicle and try moving the tire if it moves a lot then most likely its the wheel bearing.
If tire moves very little then spin tire or run hand around tread you would feel a bump in tread if it has seperated.
Feb 26, 2009 at 5:42 PM
