2000 Ford Taurus radiator drain plug
2000 FORD TAURUS
CARMENNL
  • 22 POSTS
Engine Cooling problem
2000 Ford Taurus 6 cyl Automatic 199999 miles
where is the drain plug on the 2000 ford taurus
Jul 10, 2010 at 4:27 PM
It is on the very bottom of the radiator on the driver's side.
Jul 10, 2010 at 9:43 PM
CARMENNL
  • 22 POSTS
thank you i found it .. i had to cut a section out to get to it... again thank you ...
Jul 10, 2010 at 9:58 PM
CARMENNL
  • 22 POSTS
when flushing the radiator,, turning the heat on full blast.. why is it cool air .. and not heat like its ask to have... do i need to replace or repair something
Jul 10, 2010 at 10:01 PM
If you are not getting heat, I need you to check something. When you finish flushing and refilling the system with new coolant, start the engine, let it warm up, and turn the heat on high. Feel both heater core hoses. Are both hot?
After thought. Are you running the engine while you flush the system?
Jul 10, 2010 at 10:28 PM
CARMENNL
  • 22 POSTS
yes i was running the engine.. now the heater is hot.. but its on the road. it said drive it . instructions that is. so tomorrow i will finish the flush.
Jul 10, 2010 at 10:37 PM
Let me know how it works for you.
Jul 10, 2010 at 11:08 PM
