Hi
When my car is running in either park or neutral,and the air conditioner is off,everything seems ok.RPM between 750-900 according to my OBD scanner.Now when I turn on the air conditioner the rpms drop low and cycles like that a few times,then the engine will die.
Now,for the weird part.When the car in in gear,and the brakes applied,the air conditioner is no longer a problem.The rpms hold steady after a very brief and small drop.As long as I am in gear,there is no problem.The problem is opposite of what I would expect,with the air conditioner being added load on the motor.Strange,isn't it?
Help
Help
Aug 18, 2009 at 7:59 PM
