2000 Ford Taurus panel lights
2000 FORD TAURUS
PAPY000
Electrical problem
2000 Ford Taurus 6 cyl Front Wheel Drive
panel lights wont come on were is fuse located to repair
Sep 19, 2010 at 7:18 AM
Actually, power for the panal lights come on through the headlight switch. I don't believe there is a seperate fuse for them. Have you checked behind the cluster to make sure everything is tight? Same with the headlight switch?
Sep 19, 2010 at 12:47 PM
GIOVANNI29
go under where your brake and gas paddle are the fuse box is located to the left of it
Sep 19, 2010 at 1:16 PM
That is correct. Let me know if you find it.
Sep 20, 2010 at 10:40 PM
