2000 Ford Taurus no ignition
2000 FORD TAURUS
69,000 MILES • 6 CYL • FWD • AUTOMATIC
HAROLDGUZMAN
The codes came up saying the "egr" valve was no good and misfiring was occuring on 5 and 6, and new battery. After replacing battery, EGR valve started the motor let it idle for 4 minutes. Haven't been able to keep it going since. It will act as if it wants to start however it wont run. Smell plenty of fuel and fuel pressure is at 42 psi.
Nov 27, 2009 at 9:00 PM
BMRFIXIT
  • 19,053 POSTS
Try and clean throttle and IAC valve
check it for tune up and check if coil firing all cylinders
as for the EGR code check its operation and check DPFE sensor
Nov 27, 2009 at 9:43 PM
