2000 Ford Taurus Clutch will not engage.
2000 FORD TAURUS
100,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGRYAN
  • 14 POSTS
Hi all. 2000 Taurus with 3.0L OHV engine. Even with the freon charged, the A/C clutch will not come on. The fuse and relay are fine. I've also jumped the low pressure switch, and still nothing. It's been suggested that I apply battery power directly to the compressor, to see if the clutch engages. There is also another switch in the back of the compressor, but I don't know what it is.
Does anybody have a wiring diagram for the air conditioning?
Thanks!
Apr 21, 2010 at 11:19 AM
Power the clutch from the battery and see if it engages the compressor if not the clutch is defective, now if it engages the compressor -the compressor is seized
Apr 21, 2010 at 12:53 PM
BIGRYAN
  • 14 POSTS
Thank you for your reply, but I don't understand. Do you think you could elaborate a bit?
Thanks!
Apr 21, 2010 at 1:04 PM
It's been suggested that I apply battery power directly to the compressor, Did youi? if not run a wire from the battery positive post straight to the clutch.
Also check the AC clutch relay. Do you see a black and yellow wire and also a plain black on the clutch? If so apply power to the black and yellow and see if the clutch engages the compressor.
Apr 21, 2010 at 1:16 PM
BIGRYAN
  • 14 POSTS
Thanks for your reply. I have not yet applied B+ directly to the clutch, will have to make a longer jumper wire than I presently have. I've jumped the relay, and it hasn't helped. Do you have a wiring diagram for the A/C? It looks like the clutch has 2 wires in the plug. Which post on the clutch would I hook the jumper to?
Apr 21, 2010 at 3:11 PM
