1999 Ford Taurus temp gauge
1999 FORD TAURUS
180,000 MILES • 6 CYL • FWD • AUTOMATIC
KYLEBLUE
temp gauge only shows the temperature when the heat is turned on.
May 29, 2010 at 3:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is this digital or standard gauge cluster?
May 29, 2010 at 4:57 PM
KYLEBLUE
standard gauge. needle only moves when heat is on. turn heat off and needle drops down.
May 29, 2010 at 8:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
and when the heater is turned on, is the heat blowing hot or just luke warm? is the coolant level in radiator full?
May 29, 2010 at 8:52 PM
KYLEBLUE
blowing hot air and radiator full
May 30, 2010 at 5:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
ok most likely culprit would be the engine coolant temperature sender, on the rear of engine block near the thermostat
May 30, 2010 at 12:02 PM
