1999 Ford Taurus specs
1999 FORD TAURUS
140,000 MILES • 6 CYL • FWD • AUTOMATIC
8SECSAV
do you know what is the stock tire size is for my 1999 ford taurus because when i turn the steering wheel i hear a rubbing rubber sound. so im thinking it could be my tires are too wide and maybe there rubbing together. my tire size i got on there rite now is 205 65 15.
Oct 16, 2008 at 9:44 PM
IMPALASS
  • 3,112 POSTS
Hello, there are several models of Taurus to choose from. I am looking at a GL Sedan.
The original equipment size I show is what you have, 205/65-15.
For rubbing you might consider jacking the front of the car up. Use jack stands, chock the rear wheels, be safe. Turn the steering wheel to one side. While this is giong on look at all of your fender panels. check for loose, sagging panels. Spin the wheels to see if they are rubbing on anything. Check both sides.
Again, be safe, jacks and stands can slip. Let us know.
Oct 16, 2008 at 10:50 PM
