1999 Ford Taurus oil pan gasket change
1999 FORD TAURUS
SEANROBN
Smells problem
1999 Ford Taurus 6 cyl Two Wheel Drive Automatic
how do i change a oil pan gasket on this car
May 17, 2009 at 8:39 AM
There are several bolts holding it on. Chances are, you will need to lift the engine to actually remove the pan once you unbolt it. Make sure you drain the oil before you remove the pan.
May 19, 2009 at 6:17 PM
