1999 Ford Taurus low coolant light is on
1999 FORD TAURUS
100,000 MILES • 6 CYL • FWD • AUTOMATIC
LYN81
the coolant level is good and the engine runs cool,l however the dash low coolant light is on. is there a way to reset or shut off the light or must the sensor be replaced? and where is the sensor located?
Jan 27, 2009 at 3:22 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
As this is a critical warning indicator you should not disconnect it, replace the sensor as i feel it will be faulty, i will check the location for you and advise ASAP.
Mark (mhpautos)
Jan 27, 2009 at 4:09 PM
ZACKMAN
  • 4,202 POSTS
The sensor is on the coolant reservoir (green box). It is not on the photo, but locate a 2-wire harness on the bottle. The sensor is attached to it.
https://www.2carpros.com/forum/automotive_pictures/55316_99tauruscoolant_1.jpg
Jan 28, 2009 at 12:39 AM
