1999 Ford Taurus Engine surges 300-500 RPM when stopped in
1999 FORD TAURUS
NIXOAL
Engine Performance problem
1999 Ford Taurus 6 cyl Two Wheel Drive Automatic 100K miles
IN reviewing all the questions and answers on the topic, my problem is not that radical. I am not seeing a surge of 1 or 2 thouand RPM. I do have to put the transmission in neutral when stopped in order to avoid "creep:. I have used Fuel Injector Cleaner, Fuel System cleaner all to no result.
Is this a transmission issue of an electronic sensor issue such as IAC or Idle Speed Control sensor.
Is this a fix I can do easily??
Alan Nxon
Oct 31, 2010 at 3:21 PM
Hi NIXOAL, Welcome to 2carpros and TY for the donation
Clean out the idle air control valve and also the MAF sensor with an electronic cleaner CRC and also test the throttle position sensor-
Oct 31, 2010 at 4:58 PM
