1999 Ford Taurus Crankshaft?
1999 FORD TAURUS
11,200 MILES • 6 CYL • FWD • AUTOMATIC
DMWEEKLEY
My car just stopped steering we assumed it was the power steering pump, looking in the hood none of the belts/pulleys are turning while the car is running, you can also turn the belts/pulleys by hand which I was told you shouldn't be able to do. Someone mentioned the crankshaft, would it be the crankshaft that needs replaced or a pulley do you think.
Mar 30, 2010 at 5:15 PM
BMRFIXIT
  • 19,053 POSTS
ITS THE PULLEY IF ITS THE CRANK SHAFT ENGINE WILL NOT START
INSPECT AND REPLACE CRANKSHAFT PULLEY
Mar 30, 2010 at 8:22 PM
