1999 Ford Taurus Crack in coolant reservoir
1999 FORD TAURUS
90,000 MILES • 6 CYL • FWD • AUTOMATIC
SOPHIESDADDY
Is there anything I can use to patch over area of the coolant reservoir that is cracked and therefore leaking fluid? Superglue and other epoxies won't hold because the reservoir is hard plastic polypropylene.
Would Bondo adhere to this?
Dec 22, 2007 at 5:14 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
there is no real solution to this crack, as the tank heats up and expands, the crack will keep flexing and break any sealed joint you may have achieved. Replace the tank, that is the only way to fix this problem.
Mark (mhpautos)
Dec 22, 2007 at 8:14 PM
