1995 Ford Taurus SHO 3.2L Automatic.
So I acquired this car recently from a relative and found it often either runs rough or wants to stall out all the time. Apparently my relative had this problem with the car as well. I'm pretty frustrated and tired of throwing money at it at this point, and would REALLY appreciate some advice!
What I've done so far:
1) New fuel filter.
2) Tested fuel pressure, it's OK.
3) New air filter.
4) New Throttle position sensor (because it was such a cheap and easy thing to try)
5) New EGR Pressure Switch (because it threw an engine trouble code, code gone after replacement).
6) Checked EGR system, seems to be working correctly.
7) New O2 sensors (because it threw an engine trouble code, code gone after replacement).
8) New Ignition Control Module (because engine was throwing codes 215, 216, and 217).
9) Checked all ignition system connectors for corrosion, none was noted.
Now after all that, the engine continues to throw codes 215, 216, and 217. The plugs, wires, and coilpack were replaced not long ago by my relative in an attempt to solve this same problem. I could try throwing a new coilpack at it, but I have a suspicion that's not the problem. Today I noticed that the engine is PARTICULARLY prone to the running rough and attempting to stall when the transmission is in Drive, 1, or 2. This doesn't seem to happen when it's in Park, Reverse, or Neutral.
Some other things to note:
1) The engine usually seems to run fine when it's idling in park in my driveway. However it does sometimes start to run rough and I have to keep the RPMs around 2000RPM for several minutes to keep it from stalling.
2) The car has sat for around a year without being used. I suspect the gas is stale, and I'm trying to run it out of the tank since I can't seem to be able to siphon it out. But since the car usually runs fine at idle, I'm not sure if this is even an issue.
3) ABS light is on, but I'm not concerned about the ABS system.
So my questions are:
1) What, if anything, should I try to do about the codes for the ignition: 215, 216, 217? Should I try a new coilpack? The only other ignition components left are the Crankshaft Position Sensor and Camshaft Position Sensor. I find it strange the car will usually run fine but is throwing these codes.
2) What could cause the car to be more prone to stalling/running rough when the transmission is in Drive?
Oct 22, 2020 at 1:22 PM
(Merged)
