1999 Ford Taurus Brakes lack stopping power when cold
1999 FORD TAURUS
124,000 MILES • 6 CYL • FWD • AUTOMATIC
MV520
99 Ford Taurus mileage:124K. My brake pedal is firm, but the brakes do not have sufficient/normal stopping power when cold. After several miles and stops they work great. When cold, they have some stopping power, but it takes a lot of pushing and I cannot lock them up no mater how hard I press the pedal.
This is not an ABS system. Semi metallic pads. Front Rotors & rear drums recently resurfaced and is clean of contaminates. Brakes were bled and new fluid.
So something isn't working cold. Can a brake booster or its vacuum source be temp. sensitive? Any ideas or suggestions? Thanks!
Jan 20, 2009 at 10:06 PM
BMRFIXIT
  • 19,053 POSTS
engine off
pump the brakes 4 to 5 times and hold down the paddle
start engine does the paddle fade down under your foot
it should
if not booster no good
Jan 21, 2009 at 6:29 AM
