1999 Ford Taurus Antifreeze in oil after rebuild
1999 FORD TAURUS
182,000 MILES • 6 CYL • FWD • AUTOMATIC
BASEBALL_MIKEY
Just rebuilt 3.0 OHV with remanufactured short block and new heads. During primed oil pump, usual startup, engine not turning over real easily....tight. Never did fire up, smelled gasoline. Checked oil and slightly foamy, drained oil pan and came out straight antifreeze then chocolate oil.
Suggestions. We now have it back out of the car.
Jan 4, 2008 at 5:42 PM
BLACKOP555
  • 10,386 POSTS
check your head gaskets and intake manifold gasket if you have a wet type intake manifold.
Jan 4, 2008 at 7:52 PM
BASEBALL_MIKEY
Have taken back out of car. Head gaskets look fine. But, there seemed to be an overabundant amount of antifreeze in number six piston. Was suggested that it could possibly be from the intake gasket possibly slipping out of position. Suggestions for keeping it is place was to lightly adhear to head with adhesive to prevent slippage when replacing intake manifold.
You have any other thoughts?
Thanks in advance.
Debbie and Mike
Jan 5, 2008 at 8:06 AM
BLACKOP555
  • 10,386 POSTS
yes you should try the intake gasket first since you say the head gaskets are just fine, make sure your heads are not warped also.
Jan 5, 2008 at 8:46 AM
