1998 Ford Taurus Turn Signal
1998 FORD TAURUS
100,220 MILES • 6 CYL • FWD • AUTOMATIC
HERBJW47
The turn signal on my Taurus wagon works intermittently. I have replaced the fuse twice but the signal still works only part of the time. Any suggestions?
Jan 30, 2009 at 7:31 PM
BMRFIXIT
  • 19,053 POSTS
Suspect and check combination switch (multifunction switch )
Jan 30, 2009 at 8:17 PM
DAVE H
  • 13,384 POSTS
check the Electronic Flasher.....Under left side of dash.
https://www.2carpros.com/forum/automotive_pictures/266999_flash_1.jpg
Jan 30, 2009 at 8:25 PM
HERBJW47
[quote:60b9039f70="BMRFIXIT"]Suspect and check combination switch (multifunction switch )[/quote:60b9039f70]
I removed the ignition lock and both steering column covers. Then I removed dust from the multi function switch area and sprayed it with brake cleaning fluid. My turn signal now works perfectly.
Thank you.
Jan 31, 2009 at 6:32 PM
