i replaced the head gaskets on the car and after i put everything together i started the car and it was running alright i was putting the new gasket inside the rocker arm cover gasket and i notcied oil flow had stopped on the rocker arms and the oil light came on. I shut the car off pulled the push rods to check to see if they were bent or if there was something preventing any oil flow. I cant find anything preventing flow and so now I am looking for ideas on what to look at also i have the rocker arm torq specs at 20-28 ft lbs is that the torq anyone else uses?
Sep 17, 2010 at 5:43 PM
