Rattling, white smoke
1998 FORD TAURUS
162,000 MILES • 6 CYL • AWD • AUTOMATIC
IMDATTYPAGURL
  • 9 POSTS
okay, I have a 98 ford taurus 3.0L DOH, Engine makes a rattling noise after driving for about 5 miles. When i come to a stop, the RPMS go below the 1, and the car turns off. wont start back up for about an hour. Also, my coolant leaks. took out the resevoir tank and noticed it was cracked on the bottom. replaced that, and right after i started the car, and white smoke came out the exhaust and shut off my car. wont even turn on at all now. can u please help??!!
Jul 11, 2008 at 12:44 AM
SERVICE WRITER
  • 9,123 POSTS
IS the engine turning over and not starting or is it not cranking at all (turn the key nothing happens.) ?
Jul 11, 2008 at 4:57 AM
IMDATTYPAGURL
  • 9 POSTS
it trys to start. won't turn over. but I did get it to start once. rode around the block. drives EXTREMELY ROUGH. lots of whte smoke coming from exhaust. no sign of water in oil
Jul 11, 2008 at 5:46 AM
BMRFIXIT
  • 19,053 POSTS
White smoke is a sign of head gasket failure
it must've been overheating on you
have the head gasket checked
good luck
Jul 11, 2008 at 6:06 AM
IMDATTYPAGURL
  • 9 POSTS
now it won't start at all. jus tries. is the headgasket the only thing it could be??
Jul 11, 2008 at 6:18 AM
BMRFIXIT
  • 19,053 POSTS
White smoke, no start .
I would say headgasket failure
reason for no start low or no compression
due to headgasket failure
Jul 11, 2008 at 6:24 AM
IMDATTYPAGURL
  • 9 POSTS
so what would make the car start only sometimes. like say I drive for a while. turn car off, have to wait an hour then it will start again. why does it do that?? and thanks for ur help! I really appreciate it!
Jul 11, 2008 at 6:33 AM
SERVICE WRITER
  • 9,123 POSTS
Don't discount the possiblility of multiple problems. The engine may be so hot it is causing a failure of the ignition module as an example that needs to cool off before it restarts or that steam is shorting a components(s).
Coolant may have contaminated the front o2 sensor or converter, that may be causing a no start from a rich condition or the cat plugging.
You don't want to keep driving like this or it can seriously escalate the cost from more damage.
BTW....Very...nice pic !
Jul 11, 2008 at 9:52 AM
IMDATTYPAGURL
  • 9 POSTS
your pic looks like my grandfathers austin. he drag races
Jul 11, 2008 at 3:24 PM
SERVICE WRITER
  • 9,123 POSTS
I wish I could take credit for that pic...Actually found on a google seach for something else and it caught my eye...really like it. Getting close to change it, been a few years.
I'm not real familiar with the Austins.
I was thinking it was more of a plymouth.
Jul 11, 2008 at 3:37 PM
IMDATTYPAGURL
  • 9 POSTS
well u can search for him. gary reinero. or reineros racing. in merced,ca
Jul 11, 2008 at 5:26 PM
IMDATTYPAGURL
  • 9 POSTS
ok weird! just started the car and no more white smoke?? what the hell??? my car is weird!!! why all of a sudden no more smoke??
Jul 12, 2008 at 12:12 AM
SERVICE WRITER
  • 9,123 POSTS
IS it still runing rough?
Coolant level down?
Might want to pull the plugs and pressure test the cooling system to see if it is leaking into the cylinders.
There is dye available also that can be added to the cooling system that can expose Head problems that will activate when exhaust gases are presence.
Cool story and car on you Granfather's site.
Jul 12, 2008 at 6:11 AM
IMDATTYPAGURL
  • 9 POSTS
runs a little bit rough still. not so much. did pressure check...nothing present
Jul 12, 2008 at 11:31 PM
SERVICE WRITER
  • 9,123 POSTS
Since it is obd II, might want to see what codes are present to save a little time.
Jul 13, 2008 at 7:52 AM
