1998 Ford Taurus no pressure on radiator hoses
1998 FORD TAURUS
KING FORDE
Engine Cooling problem
1998 Ford Taurus 6 cyl Front Wheel Drive 98000 miles
my son recently bought this car and there appears to be no pressure on the 2 lines coming off the radiator. car shows no signs of leaking fluid and doesnt over heat.temperture gauge is right in the middle. The heater takes sometime to warm up. The coolant reservoir appears to be ful. Could this be a bad water pump problem. or not enough fluid in the system even though the reservoir is full. The engine appears to be idoling fine and oil is clean. Any idea.
Also the blinkers and hazards dont work. fuses are good and blinkers only work ocationally with the hazards switch depressed but the hazards still dont work.
Mar 12, 2010 at 11:26 AM
MATHIASO
  • 1,209 POSTS
Hello
the hazard flasher might be bad.
it is located behind left hand side of the instrument panel at the left hand side of the steering column .
Mar 12, 2010 at 1:08 PM
