leaking transmission fluid from one of the lines
1998 FORD TAURUS
TAURUSMINE
My car is leaking transmission fluid from one of the lines. The leak is below the battery area. It's coming from the top line at the connector. Can I just replace the connector or is the line one piece?
Dec 28, 2009 at 10:57 PM
SQM
  • 6,383 POSTS
Those cooler lines typically have hydraulic fittings and connectors. If you get a leak the whole line needs to be replaced.
Thank you.
https://www.2carpros.com/articles/automatic-transmission-problems
Oct 21, 2021 at 8:44 PM
