1998 Ford Taurus engine and transfer case
1998 FORD TAURUS
BEN.ROTHSTEIN
1998 Ford Taurus 6 cyl Automatic
my question is my 98 ford taurus is got a really good knock in it and im wondering whats causeing it there was oil in the engine and i was wondering about a 1744 engine code its something with the transfer case but not sure if that i have to pull it down or what thanks for your time.
Jun 26, 2010 at 4:11 PM
BMRFIXIT
  • 19,053 POSTS
p1744 is TCC Excessive Slip
Check Electrical Signal Operation Disconnect transaxle harness connector. Inspect condition of connector and repair as needed. Using DVOM, connect positive lead to transaxle harness connector terminal No. 7. Connect negative lead to terminal No. 3. While monitoring DVOM, press START and STOP to cycle solenoid output on and off. If voltage changes at least .5 volt,
If voltage is unaffected, go to next step.
Check Continuity Of Solenoid Signal & VPWR Harness Circuits - Ensure ignition is off. Disconnect PCM 104-pin connector, and inspect it for damaged pins, corrosion and loose wires. Repair as necessary. Install breakout box, leaving PCM disconnected. Measure and record resistance between breakout box test pin No. 82 on Windstar and 1997 Sable and Taurus (test pin No. 54 on 1998 Sable and Taurus) and transaxle harness connector terminal No. 3. Measure and record resistance between test pins No. 71 and 97 and transaxle harness connector terminal No. 7. If any resistance is greater than 5 ohms, repair open circuit
Jun 26, 2010 at 7:56 PM
