The AIR code- Look for broken vacuum lines to the AIR diverter valves, broken/missing belt on AIR pump,damage to the hoses from diverter valve to the "gulp" valves at the exhaust manifolds.If all good, start and warm up car,check for vacuum at control valve on diverter.if ok then might be the gulp valves, they are one way and sometimes get rusty and stuck in position. The EVAP code might require a trip to teh shop for a smoke test to find the leak, the system will detect very small leaks
Jan 26, 2008 at 8:05 AM
