The turn signal flasher is under the dash on the drivers side. Here is a guide that can help with the problem check out the diagrams below for the location.
Check out the diagrams (Below) Please let us know if you need anything else to get the problem fixed.
Feb 19, 2018 at 2:30 PM
DRCRANKNWRENCH
CERTIFIED EXPERT
It is located behind left end of instrument panel above the fuse box. See attached diagram.
Image (Click to enlarge)
Feb 19, 2018 at 2:32 PM
(Merged)
93SHO
MEMBER
1 POST
The blinkers in my 1993 SHO Taurus have gone out same with the hazard lights, the fuses are fine, it's a 3.2 liter, with approx 160k miles. Where is the flasher, because I am sure that is the problem.
