1998 Ford Taurus compressor
1998 FORD TAURUS
141,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGJIM111
I've had problems with my air conditioner. I asked you what to do and you suggested I have the air and moisture sucked out and the system sealed. I did that and it's better but still stops cooling after awhile. I took it back to the mechanic and now he says the compressor has a leak and needs to be replaced. About $900.
What can I do? Can the compressor be sealed or must it be replaced?
Thanks,
Sep 1, 2009 at 10:22 AM
DOCFIXIT
  • 18,828 POSTS
Hi
if comp leaking then replacement is necessary. You could do it yourself and have a shop vacuum down and chage.
Let me know if you go DIY can help with instruction.
Thanks for donate
Sep 1, 2009 at 2:41 PM
