1997 Ford Taurus White smoke but no overheat.
1997 FORD TAURUS
160,000 MILES • 6 CYL • FWD • AUTOMATIC
SHADOWEDSIDHE
I picked up the car from the shop where it got new spark plugs and wires to fix a bad misfire. On the way home from the shop it drove fine. My boyfriend added coolant before we got in the car to go somewhere and now it's shaking badly and billowing white smoke from the tailpipe and engine. I didn't drive it more than 2 miles tops.
There's no sign of coolant in the oil and the car has yet to overheat. A friend says it could just be an overfilled coolant tank, but I'm dreading the possibility of a blown head gasket. What can I expect?
Nov 3, 2010 at 4:34 PM
White smoke from the exhaust indicates coolant getting into the combustion chamber (head gasket). Is the coolant level droping?
Nov 4, 2010 at 7:09 AM
SHADOWEDSIDHE
The coolant level had been dipping for about a month but it had been a very slow leak, the car hadn't over heated and I couldn't see where the leak was coming from. The car started idling very rough and misfiring at low RPMs a day or two before I took it in.
Now I'm just wondering why a blown head gasket wasn't caught at the shop before I paid for the new spark plugs. I told the mechanic that I'd been loosing coolant in addition to the rough idle. Is that kind of thing easy to miss?
Nov 4, 2010 at 11:48 AM
He should have known that right away. If the coolant is going down, there is white smoke... it's a headgasket. When you remove the plugs, a cylender that is getting coolant is easy to see. The plug will be a different color than the others.
joe
Nov 4, 2010 at 1:19 PM
