1997 Ford Taurus transmission fluid leak
1997 FORD TAURUS
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
ISM0624
My car is leaking tranny fluid but not always when I take short trips there are no leaks but when I drive for say more than a hour at a time it starts to leak at a pretty good pace it leaking from on top of the transmission down the back in between oil pan and tranny pan on the oil pan side. thank you i took it to the transmission shop but it was not leaking at that time.
Jan 25, 2009 at 10:27 PM
JGAROFALO
  • 489 POSTS
This sounds like the fluid may be foaming. There is a vent at the top of the transmission. If oil is foaming, it can be forced out the vent. There are a few possible causes of this:
Transmission could have too much or too little oil.
Planetary gearset could be failing.
Could have the wrong oil in the trans.
Air could be drawn in through a bad seal.
Try checking the oil when it is leaking. Check for foaming. Make sure dipstick is fully seated.
Jan 27, 2009 at 6:47 PM
