1997 Ford Taurus Revs up while driving
1997 FORD TAURUS
109,120 MILES • 6 CYL • FWD • AUTOMATIC
DTHOM45011
  • 12 POSTS
I have a 97 Taurus 3.0 OHV, A/T. I'll start by saying I have replaced the IAC and the TPS. The car while idling is fine. Once you start to drive for a while it will start to take off. If you put it in Neutral the RPMs rev up to about 3500-4000. I have had it in the shop a couple of times and they can't find any codes. They suggest I replace the IAC, so I did (exchanged the one I just bought), still doing the same.
Mar 26, 2010 at 10:44 AM
LEGITIMATE007
  • 5,121 POSTS
I think your throttle linkage is sticking a bit and you need a good throttle body cleaning. start by spraying the linkage with some wd 40 and then clean the throttle plate/body
Mar 26, 2010 at 10:50 AM
LEGITIMATE007
  • 5,121 POSTS
DTHOM45011
  • 12 POSTS
The Linkage isn't sticking. I have sprayed it and it's working fine. Any other suggestions?
Mar 26, 2010 at 10:55 AM
LEGITIMATE007
  • 5,121 POSTS
CHECK THE LARGE TUBE GOING FROM THE AIR BOX TO THE THROTTLE BODY, FOR A CRACK OR HOLE. THIS NEEDS TO BE AIR TIGHT OR WILL CAUSE A HIGH IDLE TOO, CHECK FOR DIRTY THROTTLE PLATE
Mar 26, 2010 at 11:03 AM
DTHOM45011
  • 12 POSTS
I will check this. However it doesn't idle high when just sitting/parked. That's what's confusing. It only happens when driving.
Mar 26, 2010 at 11:12 AM
LEGITIMATE007
  • 5,121 POSTS
so, as your coming to a stop or turning the corner?
Mar 26, 2010 at 11:15 AM
DTHOM45011
  • 12 POSTS
No cracks and is cleaned (used Carb cleaner on TB plate. Ran for few mins. Then drove, still reving up after driven for a few mins. Doesn't do it when Idling though.
Mar 26, 2010 at 11:39 AM
DTHOM45011
  • 12 POSTS
It does it when I am driving. Not just while stopping or slow turns around corners. Anytime the car is moving for more than a few miles.
Mar 26, 2010 at 11:42 AM
LEGITIMATE007
  • 5,121 POSTS
try cleaning th mass airflow sensor too.
Mar 26, 2010 at 12:20 PM
DTHOM45011
  • 12 POSTS
I stopped on the way home and bought a new one and replaced it today and still having same issue. Still no codes.
Mar 26, 2010 at 8:24 PM
LEGITIMATE007
  • 5,121 POSTS
two things, one, check the mapp sensor, two,pcv valve,
Mar 27, 2010 at 6:34 AM
DTHOM45011
  • 12 POSTS
I replaced MAP Sensor and the PVC Valve has good suction on it.
Mar 27, 2010 at 6:55 AM
LEGITIMATE007
  • 5,121 POSTS
ok I will have to ask for some help on this one, im stumped. I will put this in the moderators forum, someone will have your answer, hold tight.
Mar 27, 2010 at 7:14 AM
RPM's going high sky while on part throttle-Did you properly seat the TPS if so check the closed idle and wide open throttle voltages as per repair manual specs
Mar 27, 2010 at 1:17 PM
DTHOM45011
  • 12 POSTS
Had the TPS replaced, under warranty. Had it checked out after installed. Working properly. Still, while driving car wants to REV up on it's own. Only happends while driving, NOT while idiling.
Mar 29, 2010 at 11:19 AM
When its happening is the check engine light coming On or has flashed before prior to this problem?
Mar 29, 2010 at 1:00 PM
DTHOM45011
  • 12 POSTS
There is no "Check Engine" light and it doesn't come on at all.
Mar 29, 2010 at 7:21 PM
What is the speed range range before it goes high? You sure the transmission is not slipping in/out Hook up a fuel pressure gauge and monitor the fuel pressure before it goes high. BTW at anytime did you disconnect the battery while replacing parts Lets try the relearning process below and also select your type of tranny If it doesn't work-Get the computer tested
https://www.2carpros.com/forum/automotive_pictures/12900_r1_5.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_r2_5.jpg
Mar 30, 2010 at 12:55 AM
LEGITIMATE007
  • 5,121 POSTS
I agree, I love your persistence Ras. very nice finding
Mar 30, 2010 at 6:16 AM
DTHOM45011
  • 12 POSTS
Ok did that resetting as directed on the last post (Thanks). This happens at speeds above 20 MPH. It is still doing it and the Transmission isn't slipping. I feel like I can't win with this one.....?????
Thanks for all of your help, I'll keep trying :-)
Mar 30, 2010 at 10:55 AM
legitimate007 has given you the probabilities and me following it what's missing to cause this problem and still not working-Last place for me is to reflash the computer
Mar 31, 2010 at 4:30 PM
