1997 Ford Taurus Replace key for 1997 Taurus GL
1997 FORD TAURUS
DAVBARSTELL
Electrical problem
1997 Ford Taurus 6 cyl Automatic
My daughter has a 1997 Taurus GL and she has lost the key. The locksmith has hesitated making a new one because of the possibility that it has an electronic sensor (or something like that) on the key. Can you confirm for me whether this car had that feature or will a standard key work? Thank you
Mar 22, 2010 at 12:49 PM
BMRFIXIT
  • 19,053 POSTS
Most likely it does
when door open check in dash for theft light on or blinking
KEY INITIALIZATION
Key initialization erases all keys in memory. This provides reprogramming of PATS module in the case where all programmed keys were lost, or to remove any key codes from memory. This procedure also allows for reprogramming of system if ignition lock assembly requires replacement.
Lock smith should have the equipment to initialize the procedure
Mar 22, 2010 at 7:31 PM
