Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Taurus
Brakes
Pads
Rear
rear brake pad replace
1997 FORD TAURUS
LYNDEN56
MEMBER
1 POST
FOLLOW
I can not get the piston on the rear caliper to go back, it seems like the emergency brake is holding it out but the cabel is fully extended
Oct 25, 2008 at 10:05 AM
BLACKOP555
CERTIFIED EXPERT
to retract the piston you need a piston remover/installer tool number T87P-2588-A
siimply rotate piston clockwise until piston is fully retracted into the bore.
make sure the slot in the piston is position so it will engage wiht the pin on the brake pad.
Apr 5, 2021 at 11:29 AM
BLACKOP555
CERTIFIED EXPERT
