1997 Ford Taurus Noise coming from the front
1997 FORD TAURUS
200,458 MILES • 6 CYL • FWD • AUTOMATIC
LESORCAN
When I come to a stop sign and am rolling up to the stopline I hear a clacking sound that diminishes and stops as the car comes to a complete stop. When I start to go again the sound is heard again but either stops or I can't hear it because of noise from traffic, etc. Any thoughts and can an "adventurous" do-it-yourselfer handle the repair(s)? The donation is all I can afford. Thanks.
Oct 28, 2010 at 7:13 PM
CARADIODOC
  • 34,306 POSTS
Hi lesorcan. Welcome to the forum. If you have plastic wheel covers, pop the front ones off. If the noise is gone when driving in rain, that's another clue the wheel covers are squeaking. A light coating of any kind of grease where the metal inserts contact the wheels will stop the noise.
If the noise is louder than the light squeaking, it could be loose brake pads. In itself that is not a serious problem but it usually occurs when other things are worn. That would be a sign you're due for a brake system inspection and a steering and suspension inspection. Loose brake pads will also rattle over bumps, and they will be quiet when you have light pressure on the brake pedal.
caradiodoc
Oct 28, 2010 at 7:38 PM
LESORCAN
caradiodoc
Caradiodoc,
I don't have plastic wheel covers. What can you tell me about the wheel hub assembly and can an adventurous do-it-yourselfer with the correct tools do the job?
Regards, Les
Oct 29, 2010 at 8:38 PM
CARADIODOC
  • 34,306 POSTS
Start by checking lug nut torque with a torque wrench. Sounds funny but all professionals have been doing that since the '80s for a number of important reasons. A typical value is around 95 ft / lbs, but 80 is more common with cast wheels.
Next, raise the front end off the ground and run the engine in gear. If you hear the sound, it's not wheels, but look at the brake calipers to see if they're moving side-to-side once per wheel revolution. If they are, you likely have a combination of a warped rotor, which is not uncommon, and grooves worn into the caliper mounting surfaces where the pad backing plates ride. Machining the rotor or putting some high temperature brake grease on the mounts will stop the noise, but machining the rotor is the permanent fix.
Look for anti-rattle hardware that is broken or mispositioned and rubbing on the rotor. There are different configurations so you might have to compare the left and right sides. Look around the inside of the wheel for "witness marks" left by something scraping. Don't overlook a wheel weight that has loosened and is hitting a bracket on the strut. If a brake pad is rattling, it will stop when you put light pressure on the brake pedal.
While the tires are off the ground, grab the wheel on top and bottom with both hands and twist it in and out. There should be no looseness. If there is, check the lower ball joint for sideways movement between the ball and socket. If it's the wheel bearing that is loose, it will allow the wheel to tip in on top, possibly allowing the wheel to rub on the caliper. The wear has to be pretty bad for that to happen. Worn ball joints are fairly common. They will allow the bottom of the wheel to squirt out tipping it in on top. If you need to replace a ball joint, it is a little easier than the less expensive pressed-in ball joints, but thee are a few tricks I can share. No special tools are needed other than a few wrenches, but because of manufacturing tolerances, the car should have an alignment after that service. There is a way to eliminate that need but it involves replacing only one joint at a time.
Front anti-sway bar links have been a real common problem on the Taurus. Unless they changed the design, it is about 15" long, parallel to the strut, and attached to the strut on top. With the wheels on the ground, reach over the top of the tire and wrap your fingertips lightly around the link, then use your arm to raise the vehicle up and down by the fender just a little. If one of the ends is worn, you will feel the clunking with your fingers. There's a ball and socket on each end, and the balls are retained by filling the sockets with molten plastic and expected to last. The link will swivel on the joints but they shouldn't rattle or feel loose. Usually they do not make a metallic sound, but more of a thumping sensation that is felt, not heard.
caradiodoc
Oct 29, 2010 at 9:31 PM
